Discuss Wiring for patio heater in the UK Electrical Forum area at ElectriciansForums.net
we don't know your level of competence, so hard to advise. all i can sayis that regs. state " a load of > 2kW should be on it'sown dedicated circuit." a 2.2kW hot tub comes fitted with a 13A BS1363 plug. if that's any guidance.
Any idea which Reg that is Tel? cuz I am arguing with a friend of mine and quite honestly I can't find a reference, other than a recommendation.
SOZ. PETE. As post 7. guidance.
and if they are the infra red type. be prepared to replace the elements every 2 months @ £10 each.
Reply to Wiring for patio heater in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
