Discuss Rise in resistance during test video in the UK Electrical Forum area at ElectriciansForums.net
Why does the resistance go up during this test?
View: https://youtu.be/8040r2iLqyM?t=1150
In fact it goes up several times during the video. Is this the wire charging up from capacitance? I'm clueless.
There could be many reasons for this, continuity is being measured between the live and the earth which are linked together at the DB.
Without being able to investigate what is causing the rise we can only guess.
From experience those probes don't always fit inro those connectors very well so there may not be good contact pressure causing the reading to rise.
It's possible the capacitor in the fluorescent could be charging if there is a N-E fault or if the earth is still connected to the earth bar.
Other possibilities are that the test link is slightly loose, there could be a slightly loose joint somewhere in tbe circuit or it could be a problem with the test leads or tester itself.
Makes sense, like given. I have to admit its kind of cool that UK electricians know ohm values of the top of their heads for any given length of twin and earth.
Generally speaking we don't know off the top of our heads, but the resistance per metre is available in the on site guide to the regulations.
Most of us can remember the earth fault loop impedance limits for common circuit ratings though.
Reply to Rise in resistance during test video in the UK Electrical Forum area at ElectriciansForums.net
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
Hi all, Testing question for you. I'm currently testing an existing domestic installation. The wiring is about 20-25 years old. We have rewired...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Hi, go easy on me please, I've just returned to the trade, well I am about to, I received my Gold Card last Thursday. I've been gen'ing up for a...
