Discuss lighting in the UK Electrical Forum area at ElectriciansForums.net
Has the fault been fixed and are you going back? It’s very easy to jump in quick and make assumptions, been there and done it. ;) Stick to the basics, SAFE ISOLATION, it’s drummed into you for a reason. Good luck:)
had a similar near miss the other week. working on a lighting circuit, i asked the client (who was a mate) to switch off the lighting MCB, which he went downstairs to do. started on the job and got a tingle off a conductor.
"did you switch it off?"
"yes i turned off the RCD"
split board. RCD on sockets alone.
my fault, should have checked.
Donut, , , ,
Reply to lighting in the UK Electrical Forum area at ElectriciansForums.net
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
Woke up this morning and tried to turn on the computer (work from home) wouldn't power on, checked lights they worked fine. Went downstairs to...
Old two core cable in a lighting circuit with no cpc at any point All points had metal fixtures and fittings class1 At two points the live loop...
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
