- Reaction score
- 6,692
There’s no need for electricians now. Any Tom Dick and Harry can buy a consumer unit at an orange shed.
Without electricians, who would fix DIY disasters?
Discuss Neutral to a switch for future use? in the Electrical Forum area at ElectriciansForums.net
Whichever way it's wired a 3core does the job. It's just a matter of pros and cons for each method. A deeper box, these days, sums it up.You would still have a PL at each light fitting as you would be taking a 3core+E from the switch to the light fitting if you are looping in and out through the switch.
[automerge]1596550708[/automerge]
Yeah this is exactly what I was thinking, it’s only taking the load for the lights it will be switching. Thanks for confirmingbear in mind that eche section of 1.0mm 3 core whether switch wires or strappers, only carries the load of 1 fitting ( or multipe fittings e.g. downlights), not the load of the whole circuit.
I’m definitely only fitting 35mm back boxes minimum on this rewire, nothing less.I think running neutrals to light switches is a good idea in the larger rooms in a house. For the utility room or the cupboard under the stairs, not required.
Also is the end of the 16mm deep box here? Again for larger rooms should we only fit 25mm or deeper to allow for future flat plates/dimmers/smart switches?
It will be the same old 3 plate wiring system just with the extra core on the switch cable for neutral. Would be a nightmare to run a cable for a live.I misread regarding the 3c and twin.....no problem.
As regards neutrals at switches, in general......whichever way suits.
It's very handy at switches but I have found situations, in the past, when it has been handy having a live at the light point....for pick up.
This will be my first rewire so my first time doing it. I’m not even discussing it with my client, the labour is the same. Cost of cable is near enough the same if u go from 1.5mmTE to 1mm3C.You would still have a PL at each light fitting as you would be taking a 3core+E from the switch to the light fitting if you are looping in and out through the switch.
This is an interesting thread.
Do you guys actually do this on a rewire?
Would the main reason be so that the light switch could be usable by smart technology?
I think I may now at least discuss it with the client as an option.
Until we all team up and buy jamming devices just to get some work backin a few years electricery will be all done on WIFI or Bluetooth or something else, and there won't be need for electricians.
Good luck with your first rewire.Yeah this is exactly what I was thinking, it’s only taking the load for the lights it will be switching. Thanks for confirming
[automerge]1596629172[/automerge]
[automerge]1596629256[/automerge]
[automerge]1596629413[/automerge]
[automerge]1596629561[/automerge]
I was on an install yesterday we did in 2007.It had no ceiling. all the Apex timbers were visible as a feature so the light fittings were quite high up.I opened up one dimmer switch. First thing I see is one of the old flat 4 gang wagos (they are back again) with 3 blue wires in it. The neutrals were at the switch. We ran a single T&E to each light point. It meant most of the wiring could be done at the switch (and faultfinding). It's a sweet little system. Deep boxes highly recommended.Yeah this is exactly what I was thinking, it’s only taking the load for the lights it will be switching. Thanks for confirming
Reply to Neutral to a switch for future use? in the Electrical Forum area at ElectriciansForums.net
