Discuss 0 Megohms N-E and no RCD Trip in the UK Electrical Forum area at ElectriciansForums.net
A
AndyTheSpark
Hi All
I was re-testing a brand new install for QC purposes todayand the N-E on the IR was 0 Megohms, am I right in expected the RCD to trip. Itwas a TN-C-S system so wondered if the shared neutral and earth may have aneffect?
The IR for L-N and L-E belled out perfectly, I haddisconnected both the neutral and earth from the board to avoid anyinterference. There was nothing plugged in or spurred, but I wouldn’t expectthat to matter anyway on N-E. The only thing I didn’t do was put a load on thecircuit – would this make any difference?
Can anyone shed any light?!?! Thanks, Andy.
The RCD will only trip if there's a load on the circuit. Even with an IR of 0 Megohms N-E there will be no actual leakage current if there's no load on the circuit.
You say 0 megs but did you try to read ohms? If so what was it, minus the leads?
Were you testing from the db or in the field?
Sounds like you took the wrong neutrals out the db though.
Hi All
Hum, probably only you when you report back on your follow up investigation!
I'd start by pluuging something into the socket concerned and see what happens next!
Hi All
hi Andy
"0 MegOhms" could mean 872,176 Ohms.
If you use Ohms Law you'll get a rough idea about the limit at which an RCD (might) trip.
it will be alot less than the above!
Have I got mixamatosis..... Ah apologies if I am a digit out. Not near it (on holiday) so a bit off the mark. Maybe its down to 0.1 M Ohms. Same thing though under that it'll just read "0" on alot of testers.
which isn't necessary true. So my point stands.
Sort of.
back to the San Migger
Reply to 0 Megohms N-E and no RCD Trip in the UK Electrical Forum area at ElectriciansForums.net
Hi all, After some options/opinions on fault finding N/E fault on ring final as fairly newish to being out alone. Customer wants to upgrade from...
Long shot but thought I’d try, have a lighting circuit that trips the RCD as soon as the neutral touches the neutral bar for said RCD. Bypass that...
Hello all I have recently installed a sub main in 4mm 3-core SWA, approx length 45 metres, to feed a small garden office. Final circuits in the...
Hi all, Was wondering if anyone has come across this before and could maybe help - Its a new one to me! Customer recently altered layout of...
I had a fault finding job on Thursday, intermittent RCD tripping. 2 actually, there was a 30mA RCD upstream, and a 30mA RCBO protecting the...
5K
