Bulk Workwear - Clothing Suppliers for the Whole Forum Network
Discuss 1 Earth Rod 2 Flats Is this allowed? in the Electrical Forum area at ElectriciansForums.net
Can 1 earth rod be the sole means of 2 flats which have a shared head coming into the bottom flat?
I have been out today and the incoming supply comes into the bottom flat. There are 2 main fuses. 1 for the bottom flat and 1 for the top flat. There is an earth rod installed outside with a 16mm earth into a henley block. 16mm then goes from there into my DB downstairs. The lateral cable supplying upstairs leaves fuse number 2 but the earth connection is also into this henley block.
Top Cat
The short answer is I don't know but I doubt it. Testing the rod would be a nightmare as you would have to chuck your lead out of the window upstairs and disconnect the downstairs flat (so no earth for the duration of the test).
The smart people on here should give you a definitive answer!:)
Pete999
That's me out then!!
If you have one service head I don't see a huge issue. The only problem would be the testing of it, if you were only testing the one dwelling both would need isolation to test the electrode resistance.
T
Toneyz
Should there be a time delayed RCD to protect the sub-main going upstairs? a photo would be useful.
Reply to 1 Earth Rod 2 Flats Is this allowed? in the Electrical Forum area at ElectriciansForums.net
Electrical2Go - Online Electrical Supplier
Top Bottom
