Discuss 1 watt gu 10 LED in the Electrical Tools and Products area at ElectriciansForums.net
I was wondering if anyone out there has used these and what they think about them.1 watt led with gu 10 base.I'm not sure but I take it they have an inbuilt transformer? They appear to save a huge amount of power running at only 1 watt as opposed to 50watt halogen.I believe they are available in a warm white but I havn't seen them in use and was wondering what the light 'spread ' is like.Other leds I have used in the past have had a very focused light output,and required the use of a transformer.
I've used these in Bathroom downlights to good effect, although you'll have to check the spread before finalising numbers/locations. They are now available as 240v GU10, so yes transformer built in.
Reply to 1 watt gu 10 LED in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
Hello, I’ve have some ten year old Collingwood SL020 RGB led garden spike lights which I’d like to keep using but wondering if I can use them with...
Hi there, I hope it's ok to post here but I have a job lot of lighting from a job and I'd like to sell them. They are all still boxed and have...
Hi Forum people. First time post here. I have a pair of semi flush fittings that are currently 10 Halogen capsules per fitting. I want to...
