View the thread, titled "100mA time delay rcd" which is posted in Talk Electrician Forum on Electricians Forums.
Hello guys,
I'm after a bit of advice/opinion on this one.
A customer has a plumis mist sprinkler system that needs power.
I'm planning to stick in a separate unit, 100mA time delayed rcd as he wants the cables buried. If I just stick a mcb off of that would that be acceptable? It's not a TT system but it's what's suggested in the manufacturers instructions.
I'm not too clued up on time delay stuff so would appreciate any input.
Cheers
Hello guys,
Cheers
For the cables to be buried at a depth below 50mm in prescribed zones you would require 30ma RCD protection
Doesn't have to be 100mA tbf, couldn't find a time delayed 30mA rcd so was an assumption off of left field I guess. Was going to use t and e to a fused spur from the CU and buried in the wall.
Well it needs 30mA rcd protection unless it complies with the reg I posted earlier. I would be looking at alterantive methods of installation to do away with RCD protection on a system loke this unless tye MI states it needs one.
Yeah would be less hassle if he'd have it surface but doesn't want it. MI suggested time delayed rcd as only viable option if buried in wall.
Like Dillb said I would look at an alternative installation method so you don't have to put it on a RCD as the manufactures instructions state a time delayed RCD or no RCD protection.
Reply to the thread, titled "100mA time delay rcd" which is posted in Talk Electrician Forum on Electricians Forums.
Paul17176,
Risteard,
