SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Discuss 10A breaker tripping problem in the Commercial Electrical Advice area at ElectriciansForums.net
Just connected 16 x gu10 50 watt lamps to a 10a breaker, wired in 1.5 T + E, havnt had time to look at the problem yet, but it trips out after a few minutes., whats the possiblities of why its tripping out, and taking so long to trip out. cheers
C
Cirrus
It hasn't exceeded the rating of the breaker Luke as you are only at about 3 Amp at the most. I would look to something else such as a fault with the terminations maybe?
  • #3
if there was a short circuit fault, at 3-4amps, would it trip a CB straight away, or would it take a while to trip
C
Cirrus
it should trip right away I think but maybe a neutral to earth fault that is causing the problem when something moves under the boards.
U
Unregistered
Guys,
If its a 10A BS EN 60898 MCB Type B then it has an instanteneous trip current of 3 to 5 times In (nominal value). Type C is 5 to 10 times In
So a 10A takes between 30-50 amps to trip straight away
A quick check of fig 3.4 (bullrush chart for 60898's) in the 17th edition tells me that at 15A a 10A breaker would take 10,000 seconds to blow, any less current and it would sit there happily forever
at a trip time of 5 minutes you've got about 18 amps flowing
Now isnt that the kind of simple, informative and accurate answer that you guys miss........
Jesus, this place is like a morgue........
regards
the ghost of a departed friend.....................
G
Grae79
ahhhh....Casper the friendly ghost has returneth.....so why'd u get booted Casper?
deano
Hi LSCOTTY
Take a current reading just to check, its most likely a faulty CB try another 10A CB.
Regards Deano
Electrical2Go - Online Electrical Supplier
Reply to 10A breaker tripping problem in the Commercial Electrical Advice area at ElectriciansForums.net
Wetroom Store - Network Wetroom Suppliers
Top Bottom
