Discuss 10mm earths on sub boards in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
jimmer
Is it acceptable to earth bond the water in 10mm to a sub board in the installation if the supply earth feeding the sub board is 10mm or greater?
or does it have to go back to the main earth terninal?
Any help much appreciated
Reply to 10mm earths on sub boards in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi, I have always used banjos when earthing the armour on an SWA but have now switched to earthing nuts. I am making off a 10mm fly lead to the...
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
Hi everyone We have some 10mm PCB RGBCCT strips (6 terminals/wires) being installed in the kitchen under the worktops However electrician is...
