Discuss 10mm swa to 10mm t&e.... in the UK Electrical Forum area at ElectriciansForums.net
But of a long story.....the swa up to my shed gave up the ghost last year and I’ve finally found another 30 metres in the back of me van....previously installed before I bought the place was 2.5 swa into a wiska box each end (rear of house to shed) 2.5 t&e from wiska via conduit/plastic pipe under floor of house and up to CU.
I can get 10mm t&e through the conduit/pipe to the wiska but not the swa so need to connect the t&e to the swa in the wiska box, hope that makes sense and as always thanks in advance
Reply to 10mm swa to 10mm t&e.... in the UK Electrical Forum area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
