Discuss 110 metre submain for 4/5 bed new build? in the UK Electrical Forum area at ElectriciansForums.net
and if there are 4/5 en-suite showers with 4/5 teenage daughters, then it's do the calcs. and X by 3.
Astonishing.
Do you think you're ready for such jobs?
Been a long day . Out the house a 5.30 this morning and just got in.Don,t really need "help" like this. I know i should be able to do this in my sleep ( kinda feels like i am) but a little guidance might be more constructive
Maybe your post could have been worded in such a way to encourage people to help you.
looking more at VD, i'd be considering 70mm.
Sorry for the vague info, i will explain more.The supply is for a 4 or maybe a 5 bed house (100A). Allowing for a 5% vd the cable size would be 50mm.
0.94x110x100/1000 = 10.34
Am i close
close, but VD for lighting is 3%, so i'd err on the side of caution. better to install a slightly oversized cable than have to dig out and replace an undersised one.
i got 70mm based on 80A demand.
5.6V drop.
Reply to 110 metre submain for 4/5 bed new build? in the UK Electrical Forum area at ElectriciansForums.net
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
Hi guys, Can I ask you a DIY question? I'm refurbing a detached garage and adding a garden building. Garage currently has a submain supplied by...
Metal building with living quarters the panel is on the outside and about 20 feet away from new build that will be 2x6 what type of shielded wire...
Hi all, I am a home owner and our builder has completed a garage conversion with the electrician installing a new 4 way distribution board. The...
I need an EICR done on a house I rent out in Reading, England - 4-bed detached built in early 1980s. Would ideally like someone from this forum...
