Discuss 110v tiles saw in the UK Electrical Forum area at ElectriciansForums.net
Why from the U.S, is it something not available in the U.K?
It may look cheap but after shipping Import Duty and Vat and the Dollar / Pound exchange rate it's not always the case.
120v is not a problem but the frequency 60hz verses our 50hz could be a problem depending on how sensitive the controls and motor are to it.
(ps. I've got an american car so I've imoorted quite a lot of car parts over the years)
As above, subject to frequency not being a problem, you would presumably need a transformer, so factor the cost of that in as well - say £50?
If it uses an induction motor the frequency will be an issue as it will run slow on 50Hz and possibly overheat. If it has a universal motor the frequency will not make any real difference. It probably won't carry European safety approvals or be intended to run from a centre-tapped supply, if you should happen to want to run it from a yellow site transformer. It will work but might only have single-pole switching whereas toold for UK site use normally have DP for this reason.
Reply to 110v tiles saw in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
I went to look at mess this morning. S plan heating system, google nest heat link in airing cupboard. Downstairs in utility room the kitchen...
Hi everyone, I have a basic knowledge of electric but would like advice before I attempt, I have a electrical item that is powered by Voltage...
Hi Guys Got a job where property is set up with Honeywell evohome TRVs and controlled via central panel. They're having an extension done with...
I am replacing some of the old receptacles in a 1940s house. Armored BX cable, two conductors, cable is the ground. Mostly pretty straightforward...
