Discuss 12 volts out when Engine Start in the Auto Electrician Forum area at ElectriciansForums.net
Blaise
hi,
I want my car stereo can power when the engine start, not when the panel lights turned-on.
in short I want the car stereo power when there is an engine acceleration.
with that wiring I can also top other wires for example my dc electric fan.
what are your ideas? suggestions?
I got someone to build a circuit that sensed difference between - resting battery voltage and 14V when charging .
Has bonus , if alternator loses the battle , amplifier loads etc get removed ! (Get an ignition /side lights sense cables included in design -if overrides are needed ) Auto/Manual/Off ...
Not as easy to sense the old Ignition/charging lamp circuit any more!
(on Modern ECU/BCU-Digi Dash-board cars)
Reply to 12 volts out when Engine Start in the Auto Electrician Forum area at ElectriciansForums.net
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
Hello everybody from Germany! I'm feeling sick with this car, it won't start, just very rarely...please help me out. Car: Opel Corsa C 1.2 2003...
I have an interesting starter circuit issue on a 2001 Toyota Celica (that won't start). If I have the starter out and have the main positive...
Hello! I'm needing some help. I'm wiring in a start panel, using a spst toggle, and a (momentary?) push button. The idea is to flip the switch to...
I have a loading arm on a vehicle powered by a hydraulic motor powered by a 12 volt motor. The motor is initiated by proximity switches on the...
