Discuss 125 HP motor speed problem in the UK Electrical Forum area at ElectriciansForums.net
Have you spoken the the rewinder, did they rewind as it was originally?
Is it 6 wire single speed?
Why did it need to be rewound, have the contactors or contacts been replaced?
Can you post a picture of the nameplate on the motor, if it can be done safely, a pic of the motor wiring terminals would be good to.
When a motor fails you need to establish the root cause, it is quite possible the motor failed because of a control issue so regardless of the rewinding been done correctly you may be subjecting it to the same issue that saw the original demise.
Have you done any testing to confirm voltages etc off and on load, also what is the starting method and what is the nature of the motor.
As above the nameplate will give us a start.
Reply to 125 HP motor speed problem in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
hello, i have a central AC Fan Coil with a 3 speed motor within my Condominium. I run the fan of low but find it blows too much air and produces...
Hi, First of all I must explain why my posting came to be on this site, I was looking on the internet for a forum that could help with a project...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
