Discuss 1250amp underground cable rating in the UK Electrical Forum area at ElectriciansForums.net
Also, what is the cable attached to at each end? e.g. reg 512.1.5.
bung in 12 lengths of 16mm T/E in parallel, spaced 6" apart.then you'll also have a UFH system as a bonus.
Given that there's something big supplying one end of this cable,
And that there's something big, important and expensive connected to the other end of the cable,
And that the cable and installation is going to cost 10's of thousands of pounds,
I would have thought an Internet Forum is NOT the place to seek advise on what size it should be.
Someone with suitable design experience should be PAID to do it.
Alternative response,, 42.
Maybe a typo? Meant to say 125A?
Still not enough info
Maybe the OP will clarify things, but I'm not holding my breath. Check out his message count since he joined.
Reply to 1250amp underground cable rating in the UK Electrical Forum area at ElectriciansForums.net
Afternoon all. Was wondering, when cables are run underground using mole/tunneling methods, how do people get around the requirement to mark...
Hi, I'm running a 70ft underground UF cable in 3/4 inch PVC conduit to 2 sheds. The sheds are 3ft from each other. I'm just a DIYer enthusiast so...
Happy New Year all. Quick question regarding cable sizing. I have a 25m run from DB to car charging unit. The 25m run will mean approx 8m is run...
Hi, I'm going to be wiring up my garden office with power and ethernet underground and I need advice on the best way to run the cables as I have...
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
