Discuss 125V L-N on cable at FCU in the UK Electrical Forum area at ElectriciansForums.net
GBDamo
Was called out to a wall heater not working, took FCU off and both L and N supply cables had snapped off. This is a spur off a ring. I have not tested the ring as cannot isolate but all plugged in equipment is performing normally.
Voltage on the exposed ends L-N was 124V, L-E 238V.
My thoughts are loose connection at the point it spurs of the ring or damaged cable.
Any other theories?
I have two hours this evening to find the fault and make safe, can't turn the power off until 18:00.
Ta in advance
You may be picking up induced voltage if you are using a digital multimeter. You could see something like those strange voltages if the N is disconnected elsewhere. Either test L-N under load, or use a proper voltage tester.
My proper voltage tester is in a ceiling in Blackpool, left it there this morning so using my Fluke 375FC clamp meter with probes to test for voltage.
When I can get in and isolate I can look for where the spur originates and get my MFT on the job.
Well what a lash up.
Turned out to be two 2.5 radials, no continuity on L,N or earth so unlikely to be a broken ring, on a 32A RCBO, traced one to the heater and no other points and couldn't find the second.
One neutral was sat in the RCBO terminal but not tight.
Found about half a dozen other C2s on the three circuits I tested so disconnected those I could and left.
Will be back another night.
Hum ........ you have no rights to leave such issues disconnected.
Yes I do, i have the trust of the customer not to leave them without critical equipment while leaving the site as safe as possible, these were non critical circuits.
Obviously I wouldn't have done this with 90 year old Doris leaving her with no heating and hot water, be more inclined to stay a few more hours to resolve.
Last time I had those figures someone had connected neutral to earth and earth to neutral on a lighting circuit. It was a TN-C-S supply.
Reply to 125V L-N on cable at FCU in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
5K
Hello, you all helped me out recently when we had a water leak (mostly in kitchen ceiling), and my landlord's contractor was saying the household...
B
Have just had a neighbour knock on my door and ask me to go round and look at a shed power supply he has attempted to install. Layout is as...
Eh up :) I don't do EICRs - not enough experience - but the things I see on some reports done by others really dismay me. Perhaps some of my...
5K
Hey all, I'm just starting to dabble in my own testing just to gain experience, while awaiting a course start. Some questions I'm not sure...
vectraj
V
