Discuss 12v - 240v Inverter in the UK Electrical Forum area at ElectriciansForums.net
F
fredflintstone
Hi,
I dont know if this is the right place to ask, but I am sure you have more knowledge on this than myself
I am looking to buy a 12v inverter so I can use the car power to get 240v
What I am really looking for is a little understanding, I understand Current, but Watts im not too sure
The inverter I am looking at is 80w and the small compressor I need to run is 97w, is it the same principle as current, ie if I plug the compressor in will it try and draw the wattage and get very hot, resulting in my car wires melting, fuses blowing etc etc.
Thanks for any help and advice, its much appreciated
An inverter will usually just shut down when overloaded, and/or blow its internal fuse. If it is a rotary compressor, although it is very small at 97W (is it a fridge motor?) the starting current will be huge and you might need an inverter of many hundreds of watts rating to start it, otherwise again it will just shut down. Tell more about the compressor.
Also, note that a typical inverter will need 10-12A from your battery to produce 97W at mains voltage, due to internal losses. This is pushing it for a cigar lighter socket as many small inverters are equipped to connect to, and might be better connected to the battery.
Reply to 12v - 240v Inverter in the UK Electrical Forum area at ElectriciansForums.net
Hi - On our small vessel we have a 12v failry powerful motor to run the autopilot, where the power is supplied by the boat's battery bank. On an...
Hello, So I purchased a Novopal 2000w/4000w(Peak) Pure Sine Wave Inverter DC 12V to 110V/120V. I purchased this so I can hook it up directly to...
Hi, I understand some basics about wattage, volts and amps etc but I am trying to decide what would be the most efficient system Situation - 2 x...
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
Hello All I was pondering an idea recently regarding the ground connection to my property. At present it has a combined Neutral to earth at the...
