Aico Carbon Monoxide Detectors
Discuss 12v ac relay not pulling in in the Electrical Forum area at ElectriciansForums.net
Hi I've installed a 12v ac relay but the 12v supply won't pull the relay coil in. It gets it signal from a disabled alarm kit. Multimeter shows a healthy 12v when alarm is activated but relay won't energise. Tried a couple of different relays but no joy. ????
uHeat Banner - Forum Discount Available
O
oldtimer
Make sure the coil is not too big for the supply it could be you have the right coil but the supply 12v may not be big enough
  • #4
Its difinetly a 12v AC coil. Perhaps the coil is too big for the 12v. Anyway I can overcome this.
  • #6
Not indicated anywhere on the kit but according to the meter its 12v AC.
O
oldtimer
You dont indicate what you are switching with the relay ? remember the alarm 12vac wil be jus enough to switch the electronics
More information is required
HandySparks
Mentor
You'd get some clue by looking at the voltage across the coil when its energised. If it's significantly lower than 12V, say less than 10V, then you may need a relay with a higher coil resistance. The relay spec sheet should say what the minimum voltage for pull-in is.
Wetroom Store - Network Wetroom Suppliers
Reply to 12v ac relay not pulling in in the Electrical Forum area at ElectriciansForums.net
Top Bottom
