Discuss 12v cabinet lights into light circuit in the UK Electrical Forum area at ElectriciansForums.net
Please help, I have just purchased wifi TCP strip light for the kitchen (multi colour and dimmer )
With a plug.
I was really hoping to have them controlled via a 3 gang dimmer switch which controls other lights in the room.
The plug has a 12 v transformer built in so I’m guessing I can’t cut the plug off and wire directly into the light circuit. (Or can I)
I could add a plug socket to the lighting circuit but understand this is not correct.
any suggestions would be really appreciated (other than get an electrician in as on a budget)
Thanks ?
Welcome to the forum mate.
No. Your light run off 12V. The lighting circuit is 230V
Nothing wrong with that, if the socket is purely for your lights. Just label up the socket.
Just put the socket above the cabinets and plug your light in.
Just be sure the socket is not on a circuit controlled by a dimmer, the power supply you plug in may not like the voltage/frequency coming out of the dimmer.
It is on a dimmer! Guess I just change it to a non dimmer switch!,
This is the key point. The dimmer 'alters' the power by chopping up the waveform to reduce its average voltage. The only things compatible with the resulting waveform are filament lamps and LED lamps that are specifically rated as suitable for dimming. Lighting containing any intelligent control requires a normal waveform of full voltage so that the intelligent bit can function.
Reply to 12v cabinet lights into light circuit in the UK Electrical Forum area at ElectriciansForums.net
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Kitchen led lights have all of a sudden dimmed by about 30% no dimmer in the system. There are 2 switches for this set of lights. Regardless of...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
