Hi All,
I have a random issue where switches on 13A switched sockets keep latching in the "on" position. Once it happens the sockets are kaput, with the switch contacts fused together. After removing the socket there is no change.
This has happened so far on two different circuits. First time was on a 2.5mm ring, approx. 30m total length - I replaced the socket, and it happened again 2 weeks later. After replacing it for a second time, so far it has been OK.
Yesterday it happened on a separate circuit - probably around a 50/60m ring. This one is a spur at the furthest point on the ring, spurred in 2.5 to an outside socket. The load prior to noticing the switch was latched on was around 2kw (inductive).
For info the sockets in each instance were Click Deco (x2) and BG - not the best I know, but it can't just be a coincidence.
Any thoughts on this one would be greatly appreciated!
