- Reaction score
- 7,754
thats ok ant ,your are only asking what I'm thinking ,nowt.That's what I asked the O.P.
Discuss 13amp Hot tub supply in the UK Electrical Forum area at ElectriciansForums.net
we have that one. it's exactly as you posted. the biggest drawback is the leccy bill.costs about £20/week.Tescos and BM seem to selling a lot of LayZspa hot tubs at the moment.
The Hot tub itself is inflatable, like a large paddling pool.
The pump/heater/bubble maker is a separate unit with quite a long lead which has a 10mA in line RCD.
The pump unit is waterproof, though I have not found an IP rating. The unit has to be next to the tub to connect the pipework and so the controls can be reached.
If you are referring to Pete999 I think calling him a twot is a bit strong.I do feel these 'like, dislike, agree etc etc' icons create more negative responses, than they set out to achieve.
I mean, why is there a 'bad spelling' icon. Do I need some **** on here to tell me, when someone has posted a reply with incorrect spelling & grammar??
I could of said, 'I mean, wheir is their a 'bid spelling' icen. Do I nead some twot on hear to till me, when someone has pisted incurrect spilling & grammer'.
Honestly,Tel? .....You've changed..........
This is what I was doing Easter weekend:
Is the enclosure you are terminating the SWA into an insulated one?The reason for heat shrink was to drop the pme earth at the FCU
As in the regs it recommends not to use PME earth.
Thing with these hot tubs, is you have to use chlorine, continuously heat and circulate the water and clean the filter daily.
Reply to 13amp Hot tub supply in the UK Electrical Forum area at ElectriciansForums.net
