Discuss 1500 watt dimmer in the Australia area at ElectriciansForums.net
T
Tapouchoke
Hi guys
I have a public house with a bank of switches x3 on each switch is 1100 watts of gu10 lights
the client has asked me to dim them I will be doing it adjacent to the board where the light switches are so space is not a problem any of you guys know where I can get three from as my wholesalers let me down
thanks for reading :cool:
another option might be to install a lutron system.... ive heard you can dim larger loads with there systems....ive never seen a 1500w dimmer think you might need a 47mm back box for it if you find one that will kick out some real heat.
i have fitted a few of these are they are not too bad compared to some normal load dimmers.
But as you say, maybe splitting the circuit would be a better idea.
Hi guys
I have used 1500 watt dimmers before but sorry I can't remember the make.They didn't fit a standard box,were only about 2 inches wide,about 8 inches high and about 6inches into wall.I'm pretty sure they were over a hundred quid. I once saw a variable speed drive used as a dimmer and I believe this costs a lot less.
I have a min of 9 GU10's to fit in a kitchen, the customer wants them all switched on together and dimmed.
Do i have to double the Wattage of each (50%) giving 900w total load, meaning I should buy the 1000w dimmer linked above ?? is this my only option? apart from splitting the lights in 2.. and is the buzzing from these dimmers when turned down anoyingly loud?
Do i have to double the Wattage of each (50%) giving 900w total load, meaning I should buy the 1000w dimmer linked above ?? is this my only option? apart from splitting the lights in 2.. and is the buzzing from these dimmers when on full load anoyingly loud?
Hi,I can't think why you would have to "double the wattage" but I recon I'd go for a standard 600watt
dimmer switch....and by the way the buzzing tends to occur when they are turned down to the minimum,this can vary with make you choose.
With halogen lamps, you have to derate the dimmer by at least 25%, this is for the 'arcing' that occurs within the lamp toward the end of the lamps life.
Reply to 1500 watt dimmer in the Australia area at ElectriciansForums.net
Morning All Got little bit situation going on, causing multiple visits (luckily only 2 mins drive from where we are.) Client not 100% happy with...
Hello! I design and build lamps, which has been a simple task so far, but I've decided to dip my toe into the dubious world of 120v LED PCBs for...
Hello everyone. Thank you in advance for any help you can provide. I tried installing a dimmer to a 3-way circuit. The dimmer has a hard...
I have the typical LED on Dimmer switch. All the lights flicker in my house are very inconsistent times. By let me clarify by saying all the...
What is the oldest dimmer switch you have seen in use recently? When did you install your first dimmer? (Veteran sparks only) I ask because a...
