Discuss 16A rotary isolator help in the UK Electrical Forum area at ElectriciansForums.net
Currently have feed to 16A rotary isolator, I’m gonna come of this with 2.5mm to a socket then to a fused connection unit to feed 2 lights if lid this ok
I don't see anything against the regs for that.
Would there be a problem if it was 32A
Depends in circuit protection.
I'm presuming, from your first post, that the circuit is protected by a 16A breaker/fuse.
Reply to 16A rotary isolator help in the UK Electrical Forum area at ElectriciansForums.net
Hi we have been asked to run a 3 phase supply into a boiler house to feed a DB fed from next to the existing meter. Would we need to install Tails...
Hi all, I'm installing a temporary supply to a modular kitchen and need to bring over a new 3PN supply for a new temp consumer unit located...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
hi ive got an unused isolator in my airing cupboard that use to run a shower. no longer have has have combi boiler feeding a new shower. the...
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
