the 2382 exams are based on look up answers therefore your tutor should have taught you how to use the book quickly to find answers
eg. picking out keywords in the question such as `disconnection` `protection``additional protection` etc
conversion of words such as fuse or mcb to `protective device`
how to find tables quickly eg any table without a letter is in the main part of the book eg table 41.2 is in part 4 chapter 41
tables with letters say 4D5 are in the appendices
tag the first table in each section so that you know the others are after the tag as some are way into the chapter, saves time thumbing through
the weighting is on part 4,5 and 7 which equates to over 60% of the questions, 60% and above is a pass
study the tables in chapter 41 and mark the 5 sec disc 41.4 as distibution circuits, remember 0.4 secs 41.2 for ALL final up to and inc 32 amps with the exception of distribution circuits
the 2382 iet/c&g exam success book may be worth buying
the questions are random and follow roughly the standard form start to finish, the singly most important thing is to read the question carefully, look for the `not` `is` `allowed` `not allowed` `are` `are not`phrases in the question
when can a water pipe be used as an earth electrde ?
what is the max tabulated Zs for a 20 amp bs88-6 protected circuit feeding a 2 way board in a garage ?
what colour is the protective conductor for a felv supply?
and finally the only book allowed in the exam room is BS7671 together with a blank notepad, a non programmable calculator and a pen
ps make sure your calculator a square root function
