Discuss 1mm Cable instead of 1.5mm? in the DIY Electrical Advice area at ElectriciansForums.net
It’s off a lighting circuit so perfect. Thank you!!!Yes you can
[automerge]1586278589[/automerge]
Although it depends on where the junction box is supplied from. If it's a lighting circuit, the answer is a resounding yes. If it's not a lighting circuit, the answer may be a resounding no because the fuse/circuit breaker for the circuit may not protect the cable in the event of a fault.
Reply to 1mm Cable instead of 1.5mm? in the DIY Electrical Advice area at ElectriciansForums.net
