Discuss 1xAL25/16 What kind of cable is that??? in the UK Electrical Forum area at ElectriciansForums.net
Hopefully a quick one.
As the title says, saw '1xAL25/16' on the side of a SWA like cable.
I know its an armored, one core, aluminium conductor, but is it 25mm² or 16mm²?
Any help appreciated.
You sure it isn't split concentric, a 25mm line conductor for a split concentric will have a cpc with a csa of 16mm.
Thanks.
That would make sense.
I'm guessing it would be a 25mm² Aluminium line conductor and 16mm² copper PEN conductor?
It's been used to serve multiple flats in a DNO system.
If its a DNO cable then likely to be as you say a 25mm aluminium line with 16mm copper concentric PEN.
Reply to 1xAL25/16 What kind of cable is that??? in the UK Electrical Forum area at ElectriciansForums.net
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Hi All, Just looking for some advice: I'm in the process of updating an old cable calc spreadsheet that helps to spit out Zs and Voltage Drop...
I am replacing some of the old receptacles in a 1940s house. Armored BX cable, two conductors, cable is the ground. Mostly pretty straightforward...
Does anyone know what the cable in the picture is called? Or anything about it? Labelling on the outside is “E SPC Electric Cable 600/1000v” Its...
