Discuss 2+2=4? Multiple 2A plug puzzle in the Electrical Forum area at ElectriciansForums.net
SJD
Mentor
Electrician's Arms
Trainee Access
Braccan heal
Something a bit more cunning, like a different phase from each plug?
Pete999
Mentor
Electrician's Arms
Northampton
You don't know if the short loop of cable is 3-core connected to the outgoing cable 3-core. … or if the outgoing cable is 4-core.
Same phase no worries
freddo
Regular EF Member
Devon
I don't like how the fourth screw slot is at a slightly different angle to the other three.
SJD
Mentor
Electrician's Arms
Trainee Access
Braccan heal
Being Lucien's post, I just wonder if it has something to do with theatrical lighting & dimmers … ?
Rpa07
4000 posts - only 54195 behind Telectrix!
Electrician's Arms
Bristol
Socket on the left is fed in from the back and is separate from the right socket, then using a ‘widow maker’ supplies the circuit extending from the right socket but at the same feeds the standard lamp so that the paramedic can identify the cause of death -
Yeh, I haven’t a clue!
Rpa07
Electrician's Arms
Bristol
The amount of cracks in that wall - I thought that my phone screen was broken!
static zap
Regular EF Member
west midlands
2nd circuit is dead ,powered by bodge ?
(a place to add hock monitor current/add dimmer)
... Need answer to is it inherently safe ?..
.. to get a better grasp !.
OP
Lucien Nunes
Lucien Nunes
Mercury Arc Rectifier
Respected Member
Mentor
Electrician's Arms
Trainee Access
Esteemed Member
London / Tallinn / Salerno
It's not lighting but it's backstage at a West-End venue.
OP
Lucien Nunes
Lucien Nunes
Respected Member
Mentor
Electrician's Arms
Trainee Access
Esteemed Member
Yes.. Speakers! They are tie-lines from backstage to FOH that run through conduits and are terminated with 2A sockets at each end. It's actually mono, so the two plugs are simply wired in parallel to the amplifier output, which at 70W into 4 ohms cannot deliver hazardous voltages to the plug pins. 2A is not used for anything else that they could be confused with, so it's perfectly OK. Installed around 1971 I suspect.
Hmm, tricker q's needed...
Electrician Talk
