Discuss 2+2=4? Multiple 2A plug puzzle in the UK Electrical Forum area at ElectriciansForums.net
Being Lucien's post, I just wonder if it has something to do with theatrical lighting & dimmers … ?
Socket on the left is fed in from the back and is separate from the right socket, then using a ‘widow maker’ supplies the circuit extending from the right socket but at the same feeds the standard lamp so that the paramedic can identify the cause of death -
Yeh, I haven’t a clue!
The amount of cracks in that wall - I thought that my phone screen was broken!
2nd circuit is dead ,powered by bodge ?
(a place to add hock monitor current/add dimmer)
... Need answer to is it inherently safe ?..
.. to get a better grasp !.
It's not lighting but it's backstage at a West-End venue.
Yes.. Speakers! They are tie-lines from backstage to FOH that run through conduits and are terminated with 2A sockets at each end. It's actually mono, so the two plugs are simply wired in parallel to the amplifier output, which at 70W into 4 ohms cannot deliver hazardous voltages to the plug pins. 2A is not used for anything else that they could be confused with, so it's perfectly OK. Installed around 1971 I suspect.
Hmm, tricker q's needed...
Reply to 2+2=4? Multiple 2A plug puzzle in the UK Electrical Forum area at ElectriciansForums.net
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
Hi all, how do you go about filling out a EIC or a minor works certificate when you have multiple installers that have worked on the circuit...
I am moving my dryer to a different room and need to add a 220 plug. Can I tap off the existing plug to add a 2nd plug in a different room? Here...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Hi, just hoping for a bit of advice. When I travel abroad (Europe, predominantly Spain/Cyprus) I usually take a single travel adaptor and a UK 4...
