Discuss 2 double switches for 2 hallway lights in the Lighting Forum area at ElectriciansForums.net
I've got 2 double switches to wire for 2 hallway lights. Each switch has cable connecting to one light then cable between the 2 backboxes, which says strap on it. How do I wire the double switches so they can turn each light on and off?20200522_135219.jpg20200522_135144.jpg
you may find that it's been wired so that both lights come on together. can't be sure without being physically there with test meter/s.
On the first picture, what is marked on the left hand cable?
There isn’t enough cables there to have 2 lights controlled by 2 x 2 way switches.
pop the backboxes out the wall and check there’s no more cables hiding in the wall.
Reply to 2 double switches for 2 hallway lights in the Lighting Forum area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
