Discuss 2 port valve no hot water nest thermostat in the Central Heating Systems area at ElectriciansForums.net
Denis00
I have a y plan system with an additional two port valve because i the hot water water tank to unvented cyclinder, installed a nest thermostat but with the two port valve connected hot water doesnt work, when removed and it then works. How can i include the two port valve the system amd stillvhave hot water?
Hi - I’m a bit lost as to why there is an additional 2 port valve, sorry.
But you can manually open the 2 port valve with it’s lever (pop it into the retainer at the end of its travel or it will close again due to the return spring). This holds the valve open and water will move in the boiler pipes to heat the hot water tank when the 3 port valve permits.
I have a y plan system with an additional two port valve because I had changed the hot water water tank to an unvented cylinder, The problem i have is when I installed a nest thermostat i get no hot water but with the two port valve disconnected hot water the hot water works. How can i include the two port valve the system and still have hot water?
Sorry for the typo in the original question its because I changed the hot water tank to a unvented cylinder,
Denis if you have added a 2 port valve because on the unvented hot water cylinder is it because it was included in with the cylinder? Only asking because my one had a 2 port valve in with it. Did you need to have the valve as you already have a 3 port valve installed? Is the cylinder in the same place as old one or moved location? Can you not replace 3 port valve with 2x 2 port valves incorporating your new one on cylinder?
It's a G3 requirement, the y plan doesn't shut off the water flow to the cylinder under fail condition.
I thought the requirement was that the cylinder couldn't be heated to >100°C... but if the MIs deem you need one... have you checked out John Ward's wiring diagram;
I'd make sure that you have some sort of bypass on the boiler flow/return if you intend to create a situation where the boiler might be pumping to nothing. Some boilers have this built in.
Reply to 2 port valve no hot water nest thermostat in the Central Heating Systems area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
(Or that might be should a failed HW valve keep boiler running) Woke up this morning to find the boiler still running even though all timers off...
