Discuss 2 questions!! in the Canada area at ElectriciansForums.net
E
evo666
My first real post and I have 2 in 1 (the start of things to come)
First one
I am a genral builder that has carried out loads of electrical work in the past (over 10 years ago) and have just done my Part P. I have taken on a job that was started by another company. The entire electrical work was completed before I started (the company was thrown of the job). Now that customer needs her Electrical Installation Certifficate, can I do it??
If so how do I complete the form as I was neither the designer or constructor??!!
Second one
I have been asked to re-wire some lights, the customer wants downlighters in all rooms. Would I wire them in series (link from fitting to fitting) or use a JB of some description (like a ceiling rose??)
I hope that makes sense
Be nice to me ;)
Evo,
Ok, you could do an EIC short form, but you have to accept that when you sign it, you are taking repsonsibility for the installation. If the customer had shock of a circuit because of problems you cant see behind the plaster etc, then bottom line is its your signature!
A 'get out' could be, that on the EIC under "extent of installation covered by this cerificate" you state that the work was carried out by a seperate contractor, although this would still be a pretty weak argument if the doo-doos hit the fan.
If the original firm were a member of NIC etc then I would be calling on them to force the frim into signing for the work they have done, as they have contravened the regs
But at the end of the day, you have no resposnsibilities (as it stands) for this installation.
i would want lots of folding stuff before i would sign off someone elses work and take responsibility for it (which you would be doing):eek:
Thats is about what I thought . Thanks for that buddy.
The only good thng about it is I did the plastering and had a check of the installation before it was done, so a little piece of mind. I have had to redo a few bits.
Just anoter quick one.......
The boiler spur is not within 2m of the appliance and it is hidden behind a draw unit in the Kitchen. To my mind I would state the the instalation is not up to BS7671. Should I change it or just run away kicking and screaming???
Again, Thanks
Evo,
It depends i suppose on how 'hidden' it is.
All connections (except crimping etc) have to be accessible for inspection and maintenance etc etc, I suppose if you were to note its location on the certs.......:cool:
seems like your 1st question has been answered correctly. i would not be too kean on signing work i have not done specially if the company that had done it got thrown out. id stay away from that if it was me, and in answer to your downlights, depending on which units you use, (i recommend JCC) its tricky to get 2 T+E 1.5mm into one light and some of them dont have terminals for the earth, when i do them i use little JBS (J210s) then a fly lead from the JB to the light, maybe a little more work but overall i find it better. also keeps earth continuity if the lights dont cater for it and if one light fails it doesnt stop the rest of them there after working. just the one light is out
Reply to 2 questions!! in the Canada area at ElectriciansForums.net
JIB Electrotechnical Certification Scheme (ECS) Level 2 and level 3 2365 question
Firstly, I’m sorry if this has been asked before - it’s just that with a thorough search I can’t find the answer anywhere. I’m looking at options...
Hi folks, I’m new to the forum and it’s this issue that lead me here. So first things first. I was looking to wire in a Smart Relay at the rose...
Guidance please - C&G L3 electrical installation - Hotel extension project Hi folks, I am fairly new to this forum but it looks like the...
