Discuss 2 speed hood fan wiring in the UK Electrical Forum area at ElectriciansForums.net
Hope someone can help
I’ve removed a 2 speed extractor motor from cooker hood with 4 cables: white, blue, black and orange.
Unfortunately the replacement motors cables are white, black, brown and red.
Can anyone advice on how to wire the new motor in
Is there no wiring information with the new motor?
If you know the wiring of the old motor ie which wire is common, low speed, and hi speed then you can usually figure out the windings of a new motor by testing the resistance between the various wires. The lower the resistance when measured with respect to the common, the higher the speed.
Unfortunately there's no reliable standard for the wiring colours. The Americans sometimes use white for common and I can't remember their usual colours for the various speeds (ASHRAE or NEMA standards). The europeans have another colour code they sometimes use (but not always) and the Chinese usually use whatever colours take their fancy on the particular day.
I'd go back to the supplier and demand a wiring diagram if I were you.
Sometimes in the installation manual, there is an internal wiring diagram. If you don't have it maybe google it. What is the make and modal by the way?
Thanks for your suggestions
It’s a 135w motor that fits in a howdens Lamona extractor hood
I will contact the supplier....as you say....surely they will be aware of the wiring colour change
SPARES2GO 135W Motor Fan Unit for LAMONA Howdens Cooker Hood Clockwise RH Directional
  • 135W Complete Motor, Connectors and Fan Housing Unit made for SPARES2GO to fit Lamona Cooker Hood / Extractor Vent
  • Fits models: All models of Lamona cooker hood / kitchen vent extractor fan with standard specifications as per this listing.
  • Specifications: Power 135W / 230V -- Clockwise Right Hand Directional Rotation -- 3 Speed motor wiring (RED = Neutral, BLACK - Live (speed 1), WHITE = Live (speed 2), BROWN = Live (speed 3) -- Case diameter: 185mm -- Diameter of fan wheel: 140mm -- Overall depth: 100mm -- Fan wheel depth: 55mm -- Connector cable length: 40mm
  • Premium quality, fully compatible complete replacement motor unit
Reply to 2 speed hood fan wiring in the UK Electrical Forum area at ElectriciansForums.net
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Hello, I currently have two switches in my bathroom. One controls the lights above the sink and the other controls a light above the toilet and...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
