- Reaction score
- 16,985
OK what exactly is high low lighting as a google finds nowt
Just look for light fittings with corridor function, most commercial type fittings have this option these days
Discuss 2 way & intermediate pir is there such a beast in the Lighting Forum area at ElectriciansForums.net
Does this corridor have any windows if not just leave one or two lights on so, not in complete darkness?No, but as @snowhead has said the corridor may not be safe plunged into darkness.
Unfortunately this is not always practical, especially if its long corridor, used by the public frequently throughout the day and evening.Does this corridor have any windows if not just leave one or two lights on so, not in complete darkness?
Good point, so if I have 6/7 switches to change over to PIR type switches in a stairwell in a small block of flats, obviously the first switch will have a permanent feed and switch line, but between that and the other switches are 3 core and earth strapper cables… So how would you recommend they be connected? One of the core’s say the brown could be carried over to each switch as the permanent feed, but which core would act as the switch line? If that makes sense… Would really appreciate it if could get back me.I may be wrong, but I thought as a PIR will turn on then turn off again, there is no need to wire it like a conventional 2 way system. Just take a PL to each one and then a feed to the lights. If any activates then the lights come on. When they are all timed out the lights are off. Or am I over simplifying it?
Kind regards Daniel
Are you fitting pir in place of the switches? Do you have n at the switch? Is it a given that all lights are operated from all switches, or can you zone them?Good point, so if I have 6/7 switches to change over to PIR type switches in a stairwell in a small block of flats, obviously the first switch will have a permanent feed and switch line, but between that and the other switches are 3 core and earth strapper cables… So how would you recommend they be connected? One of the core’s say the brown could be carried over to each switch as the permanent feed, but which core would act as the switch line? If that makes sense… Would really appreciate it if could get back me.
Kind regards Daniel
I
I would remove switches, wago in on position, fit blanking plate, then remove each light fitting and fit a pir in best position possible. Refit light, then each light has its own sensor. Without seeing the layout and light positioning its impossible to know if this would work for someone moving around the staircase. As suggested earlier, it may be appropriate to fit dual intensity light fittings.
Reply to 2 way & intermediate pir is there such a beast in the Lighting Forum area at ElectriciansForums.net
