Discuss 2 way speed potentiometer in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Status
Not open for further replies.
calpol91
Electrician's Arms
Hi guys...
Just been to have a quick look at a job, literally had 2 mins to have a gander as its a last minute job and they were closing...
They basically want a stop/start at the other end of the conveyor (theres already one at the end naturally) and to accompany that, a second pot to control the speed. Im not totally unfamiliar with drives but im not an expert by any means, but i can tell you it was only basic.
I figured have the live on each pot switched on like a 2 way some how (relay) then the other 2 wires (slider and neg.) just wired as if it was in parallel?
I haven't told the customer i can do it yet so I'm not too worried if this isn't possible...
stef
Regular EF Member
Gosport
Any drive can have only one speed demand at a time, switching between two pots gives you the problem that they can (and probably will ) be set at two different speeds. If your customer can live with that, then ok. You must connect the wiper of each pot to the switch NC and NO, and the common of the switch to the drive. Pot supply and ground in parallel. Hope this helps.
OP
C
calpol91
Electrician's Arms
Thanks for that, i think ill go ahead with that. To be honest i doubt they'll be too bothered with the speed change, it doesn't go that fast really anyway and the generally have it at full speed and only slow it to give the guy chance at the bottom to catch up... Thanks stef
K
Knobhead
There is a way to do this. But the speed control will switch between the start/stop stations depending on which starts the drive first.
If the speed is governed by one guys work speed it would make sense (to me anyway) for him to have control of start/stop/speed, the other end just having a stop facility.
OP
C
calpol91
Electrician's Arms
I agree but if the customer wants it doing, and it can be done, im not going to say no... Ive drawn it all down now, roughly and switching the slider on a no/nc rotary switch is the way forward i think :)
OP
C
calpol91
Electrician's Arms
Status
Permanent unswitched live colour?
  • Brown
    Votes: 63 67.0%
  • Black
    Votes: 31 33.0%
Electrician Talk
