I suspect the outcome of this will be "call a professional" and if so that's fine (and I will ask for a recommendation in EC London...) but I would like to understand what's going on with my wiring in any case.
It's a "simple" 2 way switching situation for the hallway light, one switch by the front door, which is wired per the first photo (the black and blue are actually joined, I just took the photo as I was removing the switch to remind myself of the positions) and the second by the stairs. There are two problems. 1 - there is no power to the stairway switch until the switch by the door is on and 2 - when I turn the switch by the door on, it takes about 4 seconds for the lights to come on.
The wiring at the first switch is below. I am really struggling to work out which wires are doing what here. One of the red wires is permanently live, the other red goes to the other switch. The yellow is permanently live (so not the switched live as I initially thought). The blue also goes to the other switch which seems to indicate that the black is the switched live.
The second switch is a different beast, actually part of a "smart home" setup but there is nothing "smart" in terms of how it works as a switch. It's wiring diagram is here:
In the backbox here I have a red (cable tester tells me it's from the other switch) a yellow (perm live) and a blue (from the other switch). The problems (1 and 2) above occur when it's wired with the yellow in "L" and the red in "Dimmed Live". The blue is currently in the middle connector. When the other switch is on, this switch works fine, turning on and off as expected, but the two certainly aren't working together in a two-way fashion. How it is working when it's patently wrongly wired (the red carries power from the other switch, so effectively I have two permanent lives connected) is a mystery to me.
Once you all stop laughing, can anyone tell me whether there is anything "bleedin obvious" that I can do myself to sort this out or do I need to put the kettle on to make tea for a professional?
Marc
Marc
