Discuss 2 wire fire alarm system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
brs73
hello there
i've just wired a 4 zone two wire fire alarn system for a very big house in the country.
all was well and we were going to use jsb/menvier but now the customer has requested a repeater panel in her bedroom. apparently menvier don't do a repeater for a two wire system.i've had a look around and i've found a firm called rafiki who 'll do what i want
i was wondering if anyone had used them before(any good??) or if anyone can recommend an alternative.it'd be very handy cos it'll save me wiring sounder circuits
cheers
forgot to say please
Ive just finished wiring up the fire alarms in the factory in which I work, we use the Rafiki Sita 200 plus board. I would recommend Rafiki. Although im not sure what 4-zone modules they do. Best thing would be to contact them direct:
  • Rafiki Protection Limited
  • 31 Springvale Industrial Estate
  • Cwmbran
  • Torfaen
  • United Kingdom
  • NP44 5BD
thanks sparky tom
i'm gonna give them a call on monday. i spoke to a wholesaler and he said they was'nt very interested in small orders.did you have a problem with that. i only want 1 4z panel ,a repeater and around ten detectors,also do they do sounder bases?
cheers
To be honest, I personally didnt order the parts; although I am sure you can buy items straight from the manufacturer.
With reguard to the bases, the bases I used for the install were all jus basic back bases, then then the different modules are pushed into the bases, they are very easy to install and to change if any are faulty. The modules I used are
multipoint with NO sounder
multipoint WITH sounder
beacon sounder
Have a look on their website, they have an online catalogue. Twinflex 2 Wire | Products | Rafiki Fire Alarm Systems
Reply to 2 wire fire alarm system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi, I need to extend a fire alarm, the panel is a CTEC CFP 2 zone one and currently it has a couple of apollo alarm sense sounder bases/heads on...
4K
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
Hi, I would be grateful if anyone could confirm the certification required for the addition and extension of a fire alarm. Scenario is, I have...
