Discuss 2 x consumer units in the Canada area at ElectriciansForums.net
B
bozo555
hello there. hope someone can help ! is it ok to fit 100a terminal blocks to the meter tails and feed 2 seperate consumer unit's .the existing consumer unit and a new smaller consumer unit with 100a main sw & rcd which would be supplying a new build extension. wanting to use job for part p inspection an wonered if there might be issue with the tails . ?
Cant see why not, as long as you use a double pole Henley block , or Ashley block or whatever they are called round your way.
However............................... I am not domestic installer registered,and have never had such an inspection, but as a method I would say it was ok.
Others might know better.
I agree with above ,but im not an domestic installer either ,but ,how else can you do the job?
or am i missing something?
Only thing to think about before you do that is having a single point of isolation for the property. Usual thing to do is to install a D.P. isolator before your henly blocks.
Reply to 2 x consumer units in the Canada area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
Hi folks, I have recently had a 5kW Solis inverter and 15kW/hr of batteries installed. Everything is working fine, but I have some concerns about...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
