C
confused I am
hi
I have rigged up DRL's (leds) into my headlight assembly , by splicing in this relay
12V LED Daytime Running Light DRL Relay Harness Automatic On/Off Switch Control | eBay
the feed was spliced into the indicator circuit which was showing 12.8v at ign on , and 13.6v when engine running , trigger wire went to dipped headlight wire and earth to common ground ,lights worked well for two weeks , then stopped working.
on investigation I have discovered that the supply voltage to the indicators is now showing about 1.8v at ign on position and about 2v when engine running , indicators still working okay .
any ideas what could have happened or how this could be possible
thanks in advance
thanks in advance
