Discuss 20A circuit in the UK Electrical Forum area at ElectriciansForums.net
hifidan
I just bought a spa which can be connected on a 120V/15A circuit. Can I use a 20A breaker if my wire to the outside box is 10 gauge and the outlet is of 20A FFT
thanks
Reply to 20A circuit in the UK Electrical Forum area at ElectriciansForums.net
Hi, I've a 50A circuit (looks like 6 gauge wire - see image) that used to service an old hot tub and I want to convert it to 20A 12/2 to service a...
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
i want to run a something like a BX cable from a sub panel in my garage through an adjacent crawlspace to a fish tank in a room just the other...
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
