Discuss 20A radial 2 double sockets in the UK Electrical Forum area at ElectriciansForums.net
Typical ratings for washing m/c 2.2kW, tumble dryer 2.5kW, an old vacuum anything from 900W to 2kW!Is a 20A 2.5mm radial sufficient for 2 sockets in a utility room? Will be a tumble dryer/washing machine plugged in and a spare socket used for a Hoover occasionally.
The return leg can be installed in some surface trunking in the corner back to consumer unit to save chasing. A vacuum might not even be plugged in, just thinking worst case loading. Likely the other socket will remain unused.If you are going to put in a return leg for the existing socket, why not put in a new radial instead, as too the Vacuum cleaner will it really be used at the same time as both the others?
Reply to 20A radial 2 double sockets in the UK Electrical Forum area at ElectriciansForums.net
