Discuss 20amp switch on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
Simba1
Hi all,
I im in the process of rewiring a kitchen and as Im taking the old cable out etc.. I come across a 20amp double pole switch.
Looking for some answer..
1. it was on the kitchen ring ?
2. It was feeding a single socket behind were the oven once was but it was in 6mm cable from the switch to the socket ?
Sounds like it was feeding an oven, not good practice!
But if it was a small oven (under 3kW) that came with a 13A plug then not an issue.
More commonly you see that for washing machines, fridge/freezer, etc, as an accessible means of isolation without pulling the thing out (which is often beyond a single person). It is not a requirement in the BS wiring reg, but in Scotland it is part of the building regs.
As pc said, sounds like it was feeding a cooker, but done badly.
Not really sure what your issue is though ? Surely if the kitchen is being rewired then all that crap will be stripped out and a new kitchen ring and cooker circuit will be installed properly ?
Reply to 20amp switch on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
Hello, Last year I had some electrical work completed in my house (New CU, SWA for garage, downlights) I informed the electrician that I will be...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
