Discuss 22 usable way split load NOT stacked in the Electrical Forum area at ElectriciansForums.net
Hi Guys.
I'm in a tight spot and require a high integrity split load 22way (28modules total ) but NOT a stacked board but in a single row. I've seen one made by Proteus/M2 but Id rather not use CEF. Has anyone else come across one?
Many Thanks in advance
I would be fitting a RCBO board .......... saves a few slots and reduces nuisance tripping
You'll be struggling for a linear one that big. I would also go RCBO at that size to save space and give a more usable system to the end user.
I use Lewden for large RCBO boards but they don't do one that big.
I use Hager for split load and small RCBO boards but they don't do anything that size without going to dual row, where their choice is plentiful.
SBS trade sales offer DP single module RCBO boards made bespoke, and the largest board they do has 22 usable ways after the main switch. Might be a good shout for this job although this still won't leave you with any spare ways if you intend to put 22 final circuits in.
Reply to 22 usable way split load NOT stacked in the Electrical Forum area at ElectriciansForums.net
