Discuss 220 Volt single phase Contactor relay controlled by 2 switches in the UK Electrical Forum area at ElectriciansForums.net
Hi,
I am looking for help wiring a 220 Volt single phase Contactor relay that has a single A1 Coil terminal to be used with 2 float switches to control a pump. I know how to connect a single switch to the relay but unsure how to add the second switch. Each switch can be Normally open or normally closed. Any help would be greatly appreciated.
Thank you in advance.
Hi,
Can you not wire the two float switches in parallel with the contactor coil?
Any drawings for this set up?
The biggest question for me is what arrangement the two float switches are in. Is there a low level switch to turn the pump on then a high level to turn it off? If that's the case then I'm afraid a single pole contactor will not be enough, you'll need a latching contact.
Reply to 220 Volt single phase Contactor relay controlled by 2 switches in the UK Electrical Forum area at ElectriciansForums.net
Hello folks, So my van got found after being stolen ;D Now I'm installing my own alarm on the van which is triggered when a door is opened. Im...
Hello all, I know this is very simple but I would like some advice please. I am installing a new circuit to feed 5 external floodlights. It is...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
