Discuss 230V caravan installation in the UK Electrical Forum area at ElectriciansForums.net
What documentation is required after wiring up a single phase installation in a caravan?
All mains testing has been done as if it were a domestic installation and tests out nicely.. I can do a domestic installation cert although the parts specifying the supply I feel are a bit superfluous as it could be from any applicable 230v supply, it's not fixed.
Also the requirements of section 721 have been adhered to.
Is a caravan classed as a Building? Does it need a Building Regs certificate?
I was going to enquire my assessor but judging from some of the comments I see on the forum, thought I'd ask here first..
EIC for provision of a new circuit or MWC for an alteration.
Record test results but state Ze/PFC etc only valid at time of test as caravan connected to temporary supply.
I think a domestic EIC, is for up to 100A supply?
Yes that's right I just checked..
And Murdoch is right too, there's no "official" domestic EIC, I just tend to call them that because that is what mainly I do.
There is similarly a Domestic Condition Report also for up to 100A..
Now we've cleared that up, perhaps we can get back to the questions on the OP? :)
Record test results but state Ze/PFC etc only valid at time of test as caravan connected to the temporary supply it was connected to when the tests were done.
Corrected that for you
If you don't state that, then some numpty could assume the tests results would apply where ever the caravan was plugged in ........ which we all know won't be the case.
CYA
CYA
Well spotted, I had my beer goggles on...
Reply to 230V caravan installation in the UK Electrical Forum area at ElectriciansForums.net
I've been given a really interesting job to do, and that's to retrofit a vintage caravan with 230v. Another company is doing the renovation work...
We have started a business building garden rooms/caravans/mobile homes under the caravan act. We have only done one so far and I got an...
Hi, I've got to a point where I need to complete the EIC for the caravan I've been working on. This isn't a static caravan, so will be going from...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
