F
Frank Spencer
Hello,
I would be very greatful if someone could help me with this problem. 2 x 230V flood lights are switched by a system consisting of 2 x 12V PIR sensors via a relay type setup with a control box. The 12 and 230v wiring goes into the relay box. There is some sort of control box (12V I think) consisting of a slider switch with 5 positions: a symbol of a person running, 1, auto, the symbol of a bell and 0. Underneath looks like two circular dials for light/dark and time. The whole lot is supplied via a FCU and is situated in a stable yard. The customer states that the lights come on but do not go off. I havent come across security lighting of this type before (have only done 230V domestic security lighting) so would be greatful for any suggestions about where I could get parts, what might be causing the problem, what the components of the system are called or even if I have overlooked something obvious. There are no manufacturers names on any of the parts. Complicated I know but thank you in advance if you could give me any information.
