Discuss 2330 - Unit 203 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
B
Billy Ashton
Hi guys i got a test coming up and come up with a question i have no clue how to work out.
If a line voltage in a 3 phase star connected system is 660v, what is the phase voltage?
Could anyone explain how this is worked out please?
Thanks Billy
Thanks Billy
If I remember correctly you multiply square root of 3 (1.73) by Line Voltage. So 230 * 1.73 = 400.
In your example it will be will be 660 * 1.73 = 1141
Thanks Billy
Your line voltage is your voltage between any two lines.........so 400v is measured between L1 and L2, L1 and L3 and L2 and L3. Your phase voltage is the voltage measured between any one line and your neutral...........L1 and N, L2 and N and L3 and N giving 230 volts.
so if you divide your line voltage in the UK by the square root of 3 (1.732) than you get your phase voltage.
So 400/1.732 = 230 volts.
Reply to 2330 - Unit 203 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
all currently working towards my 2391 c&g I&T . I know how to calculate v.d. but the mock test I found online seems a bit out of date or I'm...
Hi Guys, sorry if posting in the wrong section. I am due to start 2391-52 course soon, and there seems to be from what I have found out, a 3 phase...
I have got these questions on 2391-52 inspection and testing but can't remember option of 1st two questions. Please any suggestion will be...
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
