Discuss 2365 Connection Methods in the UK Electrical Forum area at ElectriciansForums.net
shnabz
I have an assignment for my 2365.
Question asks to list 3 methods of connection that may be used during the installation of an apartment block and a workshop.
I have screw clamping terminals for accessories.
I have screw-less terminals as an alternative.
What else?
Would compression terminations such as cable lugs or crimps be used? If so, where? Does SWA use that kind of termination?
Small SWA cables can be terminated in your 1st and 2nd choices, larger SWA cables can require crimped lugs, for example Bus Bar chambers, large items of switchgear etc, crimped through ferrules can also be used in jointing SWA cores
Depends on the size of the workshop and what sort of work is being done in the workshop, your profile is a bit vague are you a trainee?
We haven't been told what sort of work is being done, we have to make 'reasonable assumptions consistent with economic considerations and conducive to the most practical design solutions'. Sorry yes I am a trainee, I am studying C&G 2365 Level 3.
Well, make a statement/assumption that this is a large engineering workshop that has a bus bar chamber an associated switchgear, you can then use the information I have provided, crimped connections on the bus bar and switchgear. The underground joint scenario could be attributed to a damaged SWA feeding an out building.
You re welcome, have you applied to post in the trainee forum? you could get more help there.
Is the question actually referring to these types of terminal ''connection'' in the first place??
It's all very vague at the moment!!
Couldn't agree more, the questions are very vague, the only reason I knew which kind of connections they were talking about is because it mentions them in the book from C&G I am studying. There are 5 listed;
screw clamping
screw-less
soldered lugs
and cable resin joints
My installation is a complete re-wire of block of flats, and new installation of nearby workshop on the same grounds.
Reply to 2365 Connection Methods in the UK Electrical Forum area at ElectriciansForums.net
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
I've an otherwise small and simple job to do later, out of hours, fit an outdoor IP FSU for a small AC unit fed from an outdoor socket on an RFC...
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
Hi all, My first post-don't be too hard on me! I'm bonding an existing 3-phase power supply (150mm2 SWA cable) to various incoming services...
