Discuss 2394/2395 Question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
Mike Blair
Question is :
- The insulation resistance of two circuits is of 40M? an 36? respectively. When tested together what is the total insulation resistance:
answer is 19 ohms but how? can some one explain
I should point out that Rt = (R1 x R2)/ (R1 + R2) can obviously only be used with two resistances in parallel which you have in your question. With three or more resistances in parallel then use the method below.
i got you looking back through my college work n found it confused my self with series revising for my 2394/5 stressful! haha i remember in college you could use (R1 x R2)/ (R1 + R2) for only 2 the other method for more
Get your head stuck in to guidance note 3, read old chief examiners reports for previous runs and the exam success book is worth getting. Remember that terminology is key.
and just as an aside. for capacitors in parallel, just add the values. in series, use the reciprocal formula. opposite to resistors.
written exam in 2 weeks scary!! after the 3 day course i remember almost everything so im not worried about the science or math the terminology is making me crap
Reply to 2394/2395 Question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have got these questions on 2391-52 inspection and testing but can't remember option of 1st two questions. Please any suggestion will be...
Hi, I had a question in my head that turned out to two and then BANG im confused. I need help with calculation here and explanation to get this...
Hello, I have an all-in-one washer/dryer unit and it is giving me error codes. I have the manual that describes how to test the various...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi, I have question about paralallel discharging NiMH modules. I have 40 modules and one modul consist of 6 x 1.2V cell = So nominal capacity is...
