Discuss 2394/95 Practical Element in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I teach it, and it is more difficult. The 2394 is thee same as the old 2391, visual inspection board with no defects. Insulation resistance test rig, EFLI simulator. Full test rig no faults, you have to do a full test as per GN3. 2395 has non conformances in photo format, your assessor will select photos of his choice from the 20 available, using C&G guidelines, you have to identify the defects and code appropriately. Ins res test rig, EFLI simulator, and full test rig with 2 from any seven faults chosen by your assessor, you need to identify the faults (short circuit,open circuit, high resistance etc), the assessor will fix them, and then you carry on with the testing regime.
ENJOY......:wink5:
Cheers.............Howard
Reply to 2394/95 Practical Element in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Does anyone else get emails and phone calls from companies and agencies say we seen your CV and we want you to apply for our job. And when you...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
Hi all, Was speaking to a family member recently, he told me his iron recently made a bang and flash as he plugged it in to the socket, and could...
JIB Electrotechnical Certification Scheme (ECS) JIB Experienced Worker
Has anyone on here had to go the route of completing the Electrotechnical Experienced Worker L3 C&G 2346-03? Trying to get a bit of an insight...
5K
Hi all, first post so go easy! This is for people who are looking for more info on the course and exams and is from my experience of doing the...
